You guys will think me insane (I can handle that) - I have a Worcester combi and central heating system, despite having a maintenance contract I have recently been told that I will have to stand the cost of a repair £500 (because fault due to sludge in system). This is the final straw as I hate central heating system. Worst case scenario in terms of cost is replacing my combi with a multipoint and ripping out my central heating system. Would really appreciate advice.
So First, what is the fault diagnosis? And what are the symptoms? Diverter valve? Pump? Heat exchanger?
Cool down and:
1. Cancell that contract - what the point of it if you need to pay 500GBP on top of it. Good Service contractrs usually
cost 10% of the NEW equipment price per year, and include
FREE REPAIR/REPLACEMENT, if it goes south by itself... (at least with the scientific stuff).
2. Try finding GOOD independant plumber(s). Ask for their advice/quotes. Tell them that you can give them a hand if needed (esp with radiators flushing).
3. Read this:
http://www.ukplumbersforums.co.uk/c...olution-how-do-proper-cheap-job-yourself.html
4. If your's boiler still provides hot water - just keep using as it is.
5. If you definitively want a tankless water heater - just site it, so it is close to the kitchen/bath taps (on HW pipe distance, if you have space), and you don't have to ripp out the main boiler. Connect the heater in parallel with the boiler and put two isolating valves in front of each on CW and HW, so you get
RAID1-like setup for the DHW with manual fail-over (just use the one, that it's working at any time). Later on, you can restore the "degenerated" water heater array to optimal condition by fixing the combi
6. If your circumstances change, and you (or family wants) the CH or a ground source heat pump in the future - connect it to existing system after flushing and rads up-sizing.
PS: That was how I + gas safe mate had fixed HW at my place (with landlady's consent) 3 years ago, and the ~20 years valiant still provides the CH...
