Inverness Plumbers Arms member Plumber Gas Engineer Dec 10, 2024 #1 What is the difference between the 2 riello oil pumps that you can buy they both look the same but the only difference I can see. Where the solenoid is fitted there is a metal plate where the other doesn't.
ShaunCorbs Super Moderator Staff member S. Mod Plumber Gas Engineer Subscribed Dec 10, 2024 #2 mectron vs rdb Different hp connection eg male vs female and coil stem
Inverness Plumbers Arms member Plumber Gas Engineer Dec 11, 2024 #3 What would happen if you put a metron oil pump on a rdb1 ? It would still work?
ShaunCorbs Super Moderator Staff member S. Mod Plumber Gas Engineer Subscribed Dec 11, 2024 #4 Inverness said: What would happen if you put a metron oil pump on a rdb1 ? It would still work? Click to expand... No as the coil is different 2 wire vs 3 wire
