View the thread, titled "room Stats" which is posted in UK Plumbers Forums on UK Plumbers Forums.
safc
Can anyone tell me the difference between a changeover roomstat and a on/off roomstat ?
An on/off stat has a two terminals connected by a single throw switch, which is either open (up to temperature)or closed (below temperature).
A changeover stat has a double throw switch, like a two-way light switch, so it's either connected A-B or A-C, depending on whether the temperature is below or above the stat setting. It's used when you have heating and cooling systems.
Reply to the thread, titled "room Stats" which is posted in UK Plumbers Forums on Plumbers Forums.
