Been doing an en-suite, last week and into this week. Also had to swap out a wc and a basin mixer from the main bathroom they had done a few years ago.
Anyway, part of the job was to remove the old cwcs tank in the loft. Went up last week and it was full, apparently when the combi had been fitted umpteen years ago the bathroom and ensuite cold water was left tank fed.
So cut the feed for the ensuite and tapped the existing pipework into the mains, all ok and laid the ply and new travertine floor last Thursday.
Turned up yesterday and they had left me a note, can you have a look at the leak in the kitchen. Water dripping through the ceiling right where the new floor has been laid. Feck.
Couldn't understand why it had taken a week to leak. Cut out a section of the ceiling and found that it was nothing I had done. The cold feed to the wc had a spot of green on it and it was spraying through. Water off, cut out and repaired. The old bit of pipe was absolutely shagged, lumps of what looked like flux in the pipe that had eaten it's way through the pipe.
Did tell them that it may be prudent to swap out the remaining pipes under the floor just in case, but not interested.
Only seen this with flux on the outside, never on the inside.
