Hi all,
This is my first post, had no option but ask more experienced people before making expensive mistake.
I would like to put my WM on opposite side of a sink where waste pipe goes at present. I will have enough space to put tall pipe and p trap behind WM. I am planning to use 40mm pipe and run it around a room as per photo.
WM Manual states:
"Height for siphon - drain hose connection must be
minimum 60 cm and maximum 125 cm
• Max. Overall drain hose length: 2,50 m (in this
case, the maximum height for fixation is 90 cm"
I did not want to use just house, max is 2.5 anyway but the main reason is that I will put this pipe behind units without option for any maintenance. The only accessible points for maintenance will be behind WM and under sink.
Do you think that my plan will work?
Thanks!
WM Manual states:
Thanks!
