T
titania
Hello,
I have been told that it is not possible to run underfloor heating using a solid fuel stove with a back boiler.
What puzzles me is that wet underfloor really isn't any different from radiators in principle, yet you can apparently heat rads with this system? Surely underfloor is just a larger horizontal radiator, using plastic pipe instead of metal?
Ok, you cannot regulate the heat as efficiently, but it must be better than using a combi running from cylinders?
Underfloor heating needs to be on for a long time, which would use up the gas in no time. In winter, the log burner will be ticking over all day, all evening and some of the night, and be up and running again in the morning before the underfloor will have completely cooled.
It seems like a no-brainer to me ??
We have no mains gas here, and could only squeeze in a small water tank or whatever would be needed to run this system. Oil is out of the question as there is nowhere for an oil tank, and I wouldn't have it on principle anyway.
We want a combi so that we have instant hot water all year round,( have no room for a large water tank), and I like to cook with it. Using it to heat the cottage as well I don't think would be very cost efficient or practical. We have some electric underfloor also, plus two chimneys, so we have a few options, but oil and mains gas are definitely out!!!
