I
iain85
Visited a customer today who has just moved in. In their cellar they have inherited a setup with the washing machine located down there with the waste dealt with via a saniflo (only serving the washing machine).
Now the install looks like a complete bodge with push fit fittings and very little in the way of support. It runs straight up approx 2 metres (internally) in 32mm waste and then approx an additional 15 metres (externally) again in 32mm of horizontal pipe work. It appears to terminate in the ground although I can't be 100% sure as there's a huge bush in the way.
Now those more experienced in these contraptions than I, what are the regs with regards to external pipe work from the saniflo ? As it stands there will always be approx a metres worth of water in the pipe externally that will be stagnant until the next purge of the device. The reason for my visit was because the push fit fitting on the waste kept popping off during the saniflo operating. As it's a new property to my customers they don't have experiance of using it during the winter and surprise surprise it was owned by a builder prior to them purchasing. I suspect it was installed and not actually used but due to the house design relocation of the washing machine would be very difficult.
To make matters worse the property drainage is discharged to a cess pit so I can't tap into the soil stack sadly. So what's my options? At the moment I suspect this pipe discharges into the ground under the patio!
grief....
grief....
