H
HUMANZEE
Hi all😉
I have a Saniflo Sanitop which has worked fine for around 12 months.
It is currently connected to a toilet and washbasin.
If the toilet is used and flushed everything works fine.
It is only when we try to add bleach to clean the toilet or have just washed our hands in the sink with soapy water that the macerator continues to run on. When I reflush the toilet, foam pours out of the top of the fresh air filter inlet where the carbon filter sits. I am guessing high pressure water is re-entering the unit causing the foaming. I have had the unit apart and cleaned it out whilst also checking that the jubilee clip holding the tube from the motor outlet is not loose but it is still foaming. Have I missed something here. Also, should the pipe prior to the non-return flap sit loosely in the vertical pipe just after the high pressure outlet of the motor? I am guessing this is a pressure release just in case a blockage happens down the line? Many thanks.
