G
Gareth Evans
Hi there, I have a
Saunier Duval Semia Condens F30e
Its got a fault, I dont get any red lights or and error code, what happens is that when I turn the heating on or the hot water tap the boiler flames come on for about 5 seconds and the led temp reading on the front goes up by about 5 degrees then the boiler just switches off for a short period, then it comes on again and so on, meaning slightly luke warm water and radiators with just the chill out of them, I've read a few threads on here where people have similar faults and have messed about, could it be the fan or air pressure switch? strange that there are no errors and it just keeps recycling, I am an mechanical electrical engineer but obviously not gas qualified, so...if it is an easy fix what is it? can I do it? Is the boiler so crap should I cut my losses and not waste money on it and buy a new boiler, its 4 years old but I believe they have gone bust, Is there any gas engineers out there that know about these boilers? you here of engineers conming out that obviously dont know what they are doing, just swap parts and charge you for all of them not just the one needed, and are parts still available? I have seen some on ebay, Please please help before the weather gets colder!!! thanks in advance. If there are any expierienced Saunier engineers neer cheshire maybe you could pay me a visit!! Gareth Evans
Hi Gareth, welcome to the forum.
Unfortunately we can't offer you any advice and even if we could, it would be a stab in the dark! Have a look through the forum, there is a section called "I'm looking for a plumber or gas engineer" (or something along those lines!) Maybe worth a post in there.
Good luck.
post your details in the looking for gas engineer forum as youll not receeive any advice unless your gas safe registered old son. cant type quick enough!
one of the problems with these boilers is the price of the spare parts which are pretty ludicrous if i remember rightly! maybe your best bet would be to get a fixed price repair from Saunier Duval as this can actually work out good value if you end up needing an expensive part or parts!
