Got the call from a mate who has never been near one, got there boiler losing pressure, checked for leaks and cant find any anywhere on the system. No water coming from PRV outside.
Filled up to 1.5 bar and closed the F&R iso valves, stood there and watched it drop from 1.5 to 0 bar in approx 20 mins.
The expansion vessel and fill loop are on the other side of the iso valve so are isolated off, Ex vessel is remote.
Looking for internal leaks....none, removed condense pipe and lower condensing unit to check for leaking from heat ex....none.
Removed PRV pipe and still no leaking, filled up to 1.5 numerous times and still dropping to zero so filled up again to 1.5 and pump opened, small hiss and a teardrop of water from pump and back to zero.
Now scratching everything, still losing pressure and on to Intergas technical. He suggests ex vessel, and everything else I've checked, but is adamant it is not the heat ex, which I agree because there's nothing draining or dripping from it. So, finally we're down to replacing the pressure switch ???? which I've already tried to clear out, before i go ahead and order one has anyone else ever come across anything on these ??
