Quick question on the above regarding doctors surgery. I've been replacing washbasins with vanesta's as aprt of an upgrade. Into the final 4 now which are in an extension that was done about 10 years ago. The plumber 10 years ago has screwed up royally, there was an old basin that had been removed and new one fitted and water services extended to a further 3 basins on the end of the run. This basin is fed through the wall from the basin on the other side and the return terminates just before the offtakes. The plumber has teed of the feed to this basin (on the new side) to feed the extension and then created a secondary return (all in speedfit must have had a job lot of fittings, everywhere). So this secondary return is just one 15m dead leg.
Obviously I am concerned at this, but don't know the chapter and verse to quote to the practise manager so that I can leave it all and be happy with it. The rest of the plumbing is spot on, apart from this extension, which looks very much like 'builders' plumbing.
Any assistance greatly received.
Simon.
Simon.
