View the thread, titled "Seeping Immersion after replacement" which is posted in UK Plumbers Forums on UK Plumbers Forums.
U
Unregistered
Hi all,
I have just replaced my immersion element in an unvented system hot water tank. Its an Ariston Classico STD 150 (stainless steel). I used the old washer which seemed to be made of a rubber mix substance of some sort and was in good condition still. I used some WRAS approved 'Blue' jointing compound on the thread and around the washer both sides as recommended by some forums and an experienced plumber friend. Tightened it up using a momument 361t ring spanner and then gave it a single light-med hit of a hammer. Thinking that would ok, proceeded to fill the tank; checked for leaks and all seemed good. Over night, the water was heated as planned but this morning on checking, there was a slight weeping. Not a drip but wiping your finger under the element thread. Can I perhaps disconnect the electricals and re-tighten the element again with a full tank or is it risky. Or could I seal it with something like Fernex LS-x or similar?
Thank you
How about you get someone in who is qualified to work on unvented cylinders in accordance with part g of the building regulations. It is illegal for you to attempt to do so.
You also need to register for more advice.
Reply to the thread, titled "Seeping Immersion after replacement" which is posted in UK Plumbers Forums on Plumbers Forums.
