View the thread, titled "service what service" which is posted in UK Plumbers Forums on UK Plumbers Forums.
ShaunCorbs
Super Moderator
Staff member
S. Mod
Subscribed
didnt think this lasted to bad never had a service since install about 11-12 years ago
condense well couldn't fit any more dirt in there 😀
heat cell baffels stuck solid cant get them out, so needs new heat cell as cant get it out 😀
first one i have see it spraying water out the flue 😀 fan was acting like an impella for a couple of seconds
and why o why
dont they recommend pouring something down to loosen baffles.? I always struggle to get them out tbh
if i could get the heat cell out i would try but its stuck solid, and yes sodium bicarb normally helps get them loose
and with the age is it worth it esp as its not had a service
They should occur a surcharge on a price for a new boiler for the fact that it looks very inaccessible
they try and flog a tool but a tap spanner does the trick
unless seized solid
Given the limited lifespan of some boilers, maybe a good strategy is to never have boiler serviced and just replace it when its knackered. You would save on all those servicing costs and that would go toward eventual replacement. Gone are the days when boilers really needed in depth servicing anyway.
or stick an old ideal classic in that will run forever
lets work this out (worst case) decent boiler lasts 10 years all installed correctly etc
year 1 : normal service/ check £75
year 2 : normal service/ check £75
year 3 : in-dept service £ 150
year 4 : normal service/ check £75
year 5 : normal service/ check £75
year 6 : in-dept service £150
year 7 : normal service/ check £75
year 8 : normal service/ check £75
year 9 : in-dept service £150
Year 10 : normal service/ check £75
new boiler time
7 x £75 = £525
3 x £150 = £450
Total £975 saved/to new boiler
Reply to the thread, titled "service what service" which is posted in UK Plumbers Forums on Electricians Forums.
