SharkBite ice maker connection kit adapter leaks
View the thread, titled "SharkBite ice maker connection kit adapter leaks" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
I purchased a SharkBite ice maker connection kit. The kit came with an adapter to connect 1/4" (3/8" OD) PEX to 1/4" compression fitting. I tried to attach the adapter to a needle-style valve as shown in the photo and the compression connection leaked. Has anyone used this adapter part successfully? The compression connection cannot be tightened with a wrench, it looks designed to tighten by hand only. Was I supposed to use teflon tape for this connection? Unfortunately I threw away the needle valve. Later, I thought maybe the problem could be that the needle valve is a flare-style connection. Any feedback would be appreciated.
Reply to the thread, titled "SharkBite ice maker connection kit adapter leaks" which is posted in DIY Plumbing Advice on Plumbers Forums.
nrgopks,
Deleted member 120897,
