View the thread, titled "Shower cold water feed" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
R
Richierichrich
My shower is awful at the moment because the cold water comes from the water tank in the loft which is probably 1 degree in temp or even ice and the thermostatic valve is completely restricting the flow becuase of the very cold water..
A friend of mine mentioned closed systems and the fact that the water in a closed system would be warmer becuase it comes form underground.
My question is this:- rather than feed the pump from the water tank, could I split off from the feed pipe for the water tank and let that feed the pump instead? Is there any reason why I could not do this? I realise that if water is drawn from the water tank then the pressure will decrease when the float valve calls for water.
Any ideas?
Thanks very much.
Rich
hi rich unfortunately you cannot tap into the tank feed for the pump feed because it is illegal to pump mains pressure water. it has to be taken off the tank after the mains feed i.e. separate feed from tank.
Steve,
Thanks for your reply. How do they do it with closed systems, becuase if they do not have a tanl they must be feeding direct from the mains? Out of curiosity, why is it illegal?
Rich
hi sorry to jump the thread but i had a fault on a shower waste pump today, it wasn't pumping the water away when i put the stat on the shower above 3. I thought it was the flow switch failing but after reading this thread im now thinking its just the feed temp is too low can anybody confirm either way? its mains fed
Reply to the thread, titled "Shower cold water feed" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
