Shower door catching as hinge broken. Part number 1256A
View the thread, titled "Shower door catching as hinge broken. Part number 1256A" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Shower door catching as the hinge broken. Part number 1256A appears stamped on the hinge, but don't know make of shower door to be able to start tracking
Solution
Hi All,
Had the same problem so I made a replacement and printed on my 3D printer.
Here's a .zip with the STL (3d file) and GCODE (3d Print file) for the hinge. I printed and fitted - works fine.
Hope this helps
Chris.
Generally if the shower door is of a reputable manufacturer they would stamp their name on it , and hence you may be able to source their parts .
On that one , unless you are very lucky of course, its a new one you need .
Edit , door
Hi All,
Hope this helps
Chris.
Solution
I'll add this one I re-created in 3D is the top hinge. Bottom one of course is flipped sides - the STL should be able to be tweaked to make the bottom hinge if you need that one. OR if you get stuck, give us a nudge I can help I'm sure.
Hi All,
Hope this helps
Chris.
Hi Chris,
Just wanted to check that this was the top hinge? The image from the file is showing part number 1255A, not 1256A.
Reply to the thread, titled "Shower door catching as hinge broken. Part number 1256A" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
Kirkybingo,
Lou,
