C
COLESTER
I have recently had a new bathroom installed and a shower cubicle added. The hole where the waste is is almost full of water at all times and when showering the tray fills until almost spilling over onto bathroom floor. When I turn the shower off the tray does drain. We have a septic tank so when the drain becomes partially blocked from a build up of hair I can not use a regular drain unblocking chemical as it will damage my septic tank which will open up a whole new can of worms. My point is that if it is filling so quickly when it is not blocked surely it is eventually going to spill into my bathroom. My plumber is telling me it drains fine and the water is supposed to sit in waste. He has left it open because when he fits the plughole chrome cover it spills over the edge into bathroom. Can anyone confirm how much water should sit in the waste and if there is any type of drain unblocker that can be used on a septic tank?
Can I add that the plumber has been disasterous from the word go. He started the 2 week installation in October and is still returning to correct the mistakes he has made every week to this day. He installed a pump suitable for just the shower as we have low mains pressure but he connected it to every water outlet in the house which would cause it to burn out. He has had to fit a new pump that is suitable for whole of house but only when I pointed out he had installed the wrong pump initially. He also didn't fit a side entry anti-gravity flange to stop air getting trapped. This information I have recently been told by the pump manufacturer.I won't bore with you with the countless other mistakes he has made but just thought I should let you know he does not seem very competent.
Hope somebody can help 🙁
