View the thread, titled "Shower Flow Drops in Unvented System" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
davidg
Hi Guys
I am new to this forum, and my knowledge is limited to what I have learned doing DIY on traditional gravity systems.
Over the summer (?) I moved into a 10 year old house that has an unvented HW system. This house has 2 showers, but there is virtually no flow from the second one, if the first is already running. In fact there is a significant pressure drop in just one if someone flushes the toilet.
Any ideas as to what I should check first?
I did get the mains pressure checked by the Water board, and they said it was about 2.2 b and met the requirements.
David
i presume you have more of a problem with flow rate rather than pressure
2.2b isnt bad, ive seen better but its equivlant to 22m head, more than gravity
what size are the pipes? check the filter in the composite valve, is the a regulator on the water etc?
Reply to the thread, titled "Shower Flow Drops in Unvented System" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
