View the thread, titled "Shower/Mains pressure - Advice pls...?" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
W
W0ZZA1
Hi All,
I have an ongoing problem with my hot water shower pressure.
My hot water comes from a combi water heater. Originally I thought I had an issue with the shower valve inlets getting blocked with limescale from the combi boiler (the combi is around 5-6 years and a bit scaley) which was causing a block and low water pressure, causing the boiler not to fire and heat the water. I had a plumber round few times to take the shower valve off, clean it descale it and but it back on. This seemed to do the trick each time!
A couple of days ago (2 weeks from when the plumber was last round) the hot pressure dropped to such a level (again) that the boiler stopped firing when using the shower, so this time I thought I'd have a go at taking the valve off myself and cleaning/descaling it. So I turned the mains/stop tap off fully (stop tap very stiff by the way), turned all bathroom sink taps and shower fully on to make sure it had definately turned off and then attempted to take the valve off. Well....I couldn't get the shower valve off as it was just to tight so I gave up. I turned the stop tap back on, tested the shower again and guess what the water came flying out, bolier fired straight up and water got lovely and hot!!!
So now I'm thinking that maybe its not a problem with the shower valve at all but to do with the stop tap/cock or an air lock maybe....?
Has any one every come across this before. What could the issue be?
I'm pretty sure the pressue will drop again in another couple of weeks, if it does I'll try turning the stopcock off and again as this seems to have worked.
Please can anyone shed any light...?
sounds like you need to get the stopcock replaced probably the washer sticking or come loose inside.
Thanks Steve... how difficult is it to do this generally? The stopcock is really difficult to get to, its tucked away behind a flap in a little linen cupboard...
Reply to the thread, titled "Shower/Mains pressure - Advice pls...?" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
