View the thread, titled "Shower mixer taps, hot water overpowering the cold water...." which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
C
Comacomer
Plumbing world, please help
I need to find a solution for a problem with the water temperature for a shower mixer tap.
The problem being when using the shower mixer tap the hot water over powers the cold water that gets so hot it’s very uncomfortable to use the shower. It doesn’t matter how much you adjust the hot and cold temperature the hot always over powers the cold.
The shower mixer taps seem basic budget taps.
The hot water comes from the boiler and the cold water comes from the cold water mains.
The boiler has been checked over and there is no problem there.
There also seems to be a difference in size of the pipes used for the hot and cold. The hot water pipe being slightly bigger than the cold water pipe.
From reading the above does anyone have a idea why I have this problem and possible solutions.
I’ve heard of a shower mixer tap that you can buy that has a thermostatic valve. Would this be a sure fix for my problem?
Reply to the thread, titled "Shower mixer taps, hot water overpowering the cold water...." which is posted in Showers and Wetrooms Advice on Plumbers Forums.
