A
Allegra
Taps are at one end shower at the other so when someone showers the water hits the wall and overspills at the shower end as no drain as part of the bath tenants are using towels then hanging out I have tried using special rubber blockers but they are straight and the end of the bath is curvec any constructive ideas or how much it should coat to lengthen piping to water supply so bath is put back in correct position.
replies to meiaca at aol dot com based in exeter devon
thanks
Meia
I bought the house with the bathroom already fitted so i didnt fit it and yes of course obvious to do it properly photos i will have a look and see if i have any....but the bath has a high neck rest so water hits tiles and gathers at shower end not tap end where the soap indents either side would drain water away....
