View the thread, titled "shower problem" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Pauline Craig
i have a nabis 1.6 bar t-end mk 2 shower pump. When i go to use the shower the pump won't start until i take the water pipes off to bleed and then the pump starts and stops but no water comes through the shower. Can someone please help me!!!
Hi Pauline.
Is this a new pump or an old one starting to play up?
Best place to start is to check if you are getting water flow to pump,by taking off the inlet pipes and running into a bucket.
If you are getting good flow to pump,its time to check if fillters are blocked,some times built into the inlets or with strainers cut into the pipework.
Reply to the thread, titled "shower problem" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
