View the thread, titled "Shower problem." which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
mike-c
Hi folks, I was at a new job earlier at a small nursing home for a first time visit to fix a leaking radiator. As I was leaving the staff asked if I could have a quick look at a problem that they had with a shower. It is a bar type thermo shower that is attached to a pump. The problem is that it runs fine for a couple of minutes then it just dies away for a few seconds then tries to work again then dies off again and just keeps doing this. As it was my first visit, I am unfamiliar with the plumbing system. The pump also kicks into life at random times whilst the basin taps are used although the pump is solely for the shower. The pump is all neatly covered by a screwed box which I did not wish to disturb at the time as it was, as i said, just a quick look. The staff say that the water pressure on that floor (top) is pretty poor at the best of times.
Apparently it has been like that since it was fitted by a now defunct company so it has not been used. Could it be the wrong type of pump or just the general low pressure that is causing it?
Hi mike . Id look at storage tanks to make sure theyre filling ok. Clean out filters on the pump. Theyve obviously fitted the pump because the pressures are poor. While cleaning filters id run pump into bucket make sure no air locks. But check filters on shower and if its a nursing home shower might be through a tmv unless showers set at 40 odd degs max .
Really need to have a good look at the pump and get a make/model of it mate,kicking in at random times could point ti a small leak and as the pressure switch opens it kicks in the pump briefly. Flow switches and small expansion vessels should be checked if they are on the pump.
It's a Wickes model 200206. It's a 1.5 bar twin impeller. It has 22mm connections but the pipework is only 15mm. Could it be too big and emptying the pipework quicker than it is filling from the tanks?
In the manual for fitting shower pumps, well the ones I do anyway always state pipework should be 22mm to the flexis going onto shower pump. I fitted one the other day where shower pump situated at bottom of cylinder was in cupboard next to bathroom and tank was directly above bathroom so I done it in 15mm works great, however whenever there is any sort of run I do it in 22mm this is probably the problem on this job. I would suggest renewing pipework
Reply to the thread, titled "Shower problem." which is posted in Showers and Wetrooms Advice on Plumbers Forums.
