A
arashtrip
Dear All,
I moved recently to a new flat. Its heating is not combi nor gravity. It has a boiler with a big tank and a pump. Pump is working when I turn hot water tap in the bath.
I dont have any issue regarding the hearing. The only problem is shower pressure. The tub taps are very good and hot water pressure is very high. It has a mixer tap and a switch to change the flow from the tap to shower. When I switch it to the shower it is perfect for couple of seconds and the hot water pressure is becoming low. The other issue is that the shower is very sensitive to cold water tap. small increase of cold water makes the water freezing!!
What is the isssue do you think? Pump seems working fine. is it for shower head, nose, tap mixer, etc?
