View the thread, titled "Shower pump activates when hot taps are turned off" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Brooksie1963
Help!
A customer of mine has the following problem:
The shower pump in the loft comes on, just for an instant, when any of the hot taps in the house are turned off.
It's a vented hot water tank system using a Warwick flange and now with a check valve / non return valve just after the hot distribution pipe out of the flange. This was supposed to solve the problem and it didn't.
Any ideas please?
Martin
I had a customer last year with a similar problem. I traced the pipework back and found a 4" piece of pipe (dead end) coming from a tee (all plastic, plumbed by a builder). I removed this and the problem went. I imagine the water was bouncing back when the taps were closed, just enough to get the float switch on the pump going.
Help!
Any ideas please?
Martin
im sure your not suppose to have anything in between the tank and the pump,this may be causing some kick back
bob
Reply to the thread, titled "Shower pump activates when hot taps are turned off" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
