I have just installed a shower pump into an existing system the header tank is in the loft giving about 3m head and the hot cylinder is on the same level as the shower, the hot feed to the pump is up and over passing the header tank in the loft were it has an open vent pipe. there is a pressure boosting pump on the hot feed from the cylinder that I think has failed as the flow to the shower pump is inadequate and dose not change when you adjust the manual settings.. the flow to the taps in the bathroom is ok but the shower pump is shutting off due to poor flow.
I sealed the vent pip temporarily to see if it was the problem but this didn't have any effect on flow due to air been sucked in.
Please advise.
Please advise.
