View the thread, titled "shower pumps" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
I
iannegus
Hello
My parents have recently moved into a bungalow. There is a thermostatic shower installed. The problem is there is a single pump in the loft for a dedicated cold water line and there is a single pump tee'd off the hwc hot pipe. These both work ok only when you start mixing the shower they start surging. Is this because the pumps are in different places and not getting equal pressure? Thankyou in advance for any advice
Both hot and cold fed from same tank, if not are both tanks at same height?
Have you stripped the shower and cleaned any filters?
Does the shower have integral check valves? Are they working correctly?
Ideally it would be better to have a twin impellor pump.
Reply to the thread, titled "shower pumps" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
