I have two showers at first floor level fed by a Worcester Combi boiler. Both showers are Mira Agile thermostatic mixer showers and are fed from the same hot and cold supply runs. One shower has been in for approx 2 years and at the moment is working fine. I had temperature fluctuation problems with the other (which has been installed for about 4 years) about 8 months ago and replaced the cartridge and the filters. At first the new cartridge did the trick, but I'm getting the same temperature problems again now, and I notice the boiler is cycling as the shower temperature goes up and down. As the newer shower is working ok I assume the problem is not with the boiler. I am wondering if the replacement cartridge is the culprit? Any thoughts/ other suggestions would be appreciated. Many thanks.
