Shower trap blocked but waste pipe is hidden
View the thread, titled "Shower trap blocked but waste pipe is hidden" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Just moved into my first house and the waste water in the shower is only draining slowly. Soda crystal, baking powder and vinegar work for a few days but then it comes back. When I use them it kind of collects at the bottom and dissolves rather than go down to the blockage.
I’ve tried some manual methods but the shower trap seems to have a hidden waste pipe. I can get my fingers down and I cannot feel a hole anywhere. It will only drain if enough water is poured in so I think it must be hidden above the area I can access. I’ve attempted to twist the cover but it wouldn’t budge so might not be a screw.
Can you recommend an unblock method for this kind of trap or how to access it. Worried I might need to get under the floorboards.
Thanks guys, I appreciate any advice you might have.
Steve
Reply to the thread, titled "Shower trap blocked but waste pipe is hidden" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
Stepheny2k2,
Stepheny2k2,
