View the thread, titled "shower vale problem (Armitage hanks Hero 6953/4)" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Hello,
After re-assembling the valve and re-fitting to body, the cold water will not flow properly. (this is without the shower-mate pump working)
(I have the manual which is quite comprehensive with exploded views of the valve so I am sure I have put it together properly.)
If I take the valve assembly out both the hot and cold water flow fine but as soon as re-fit it the cold won't flow.
If i remove the rear spring and distribution assembly (and just fit the rest of the valve) both cold and hot flow fine, as soon as I add those parts I have the problem
Any ideas please
Regards,
ppeetteerr
Reply to the thread, titled "shower vale problem (Armitage hanks Hero 6953/4)" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
