View the thread, titled "Showerforce 2000 advice needed" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
J
jeannie
Hi, My Showerforce 2000 stopped working a few days ago whilst using the shower. Water still comes through but the pump isn't pumping. Am guessing the pump may have worn out. I have no experience of plumbing whatsoever. But I wondered whether replacing the pump is simple enough for a novice to do. Any advice would be much appreciated. Thanks
you could test the fuse and/or open it up and check to ensure the pump is getting power through before assuming it's the pump ? we had one in our last house - think there was a transfomer in the loft which you may also need to check
Reply to the thread, titled "Showerforce 2000 advice needed" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
