View the thread, titled "sime 30he format and ecomfort boilers" which is posted in Boiler Advice Forum on UK Plumbers Forums.
R
rm1
i am constantly attending these boilers and have discovered that the micro switch is a common fault that needs replaced is it just a bad micro switch design or does any body have any other ideas that would cause the problem
on one tomorrow, good tip, shall keep in mind. assume sequence is pump, microswitch, high stat, fan , ignition ,etc
Reply to the thread, titled "sime 30he format and ecomfort boilers" which is posted in Boiler Advice Forum on Plumbers Forums.
