View the thread, titled "sime friendly format 100 e" which is posted in UK Plumbers Forums on UK Plumbers Forums.
pgr
can someone tell me if my central heating pipes should get hot when running hot water only .(central heating off) or is the diapham in diverter valve is cracked.
thanks
the divertor valve is not closing off heating correctly,not due to diaghram,valve requires stripping and cleaning and pins lubricated
yes near radiators get warm .
well regards to cleaning and lubricating do i need new gaskets and what do you lubricate with?
thanks
thanks
all combis dump heat after hot water has run but should only be a minute at the most so yes first rad can get warm but shouldnt stay warm
Reply to the thread, titled "sime friendly format 100 e" which is posted in UK Plumbers Forums on Plumbers Forums.
