View the thread, titled "Single flow mixer tap ok on kitchen sink" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Yep , you only really need check valves when on gravity systems , doesnt really matter on combi systems
Thanks will have check valves as gravity hot and cold mains, just wonderd if this taps were ok for drinking water with the water mixing in the tap
Yes you will be fine , loads of taps do this . I guess they are a load easier to manufacture
Reply to the thread, titled "Single flow mixer tap ok on kitchen sink" which is posted in UK Plumbers Forums on Electricians Forums.
