Hopefully this is an easy fix......
I have moved into a house and some of the work is 'interesting', things you never see when looking originally. Our latest problem is that the sink fills with water when the washing machine empties and also when you empty the adjacent 0.5 sink. The pipework is connected as in the photos dishwasher > 0.5 sink > 1.0 sink this then goes through the wall into a u-bend and into a junction where the washing machine pipe joins it after a u-bend (also the overflow bit from the boiler, or whatever it is) this is all then plumbed into the foul 110mm pipe.
The pipe that goes through the wall is quite high up and I guess this is why there are no traps under the sinks and the u-bend is after the wall. I do intend to drop this down so the fall is greater but it is a 2ft stone wall so this is obviously not an easy task.
Could the issue be that no air can enter the system? Or the very shallow fall on the pipe under the sink.... Or something else?
In the long run, the kitchen will be redone, with a toilet where the washing machine is, would this cause issues if all drianded into this and the toilet?
Thanks in advance
BRS82
Thanks in advance
BRS82
