Hi again, I recently installed an Wickes Compact Sink with the help of you guys on here successfully, no leaks on the underneath plumbing bits after a month.
But I could just be fussy or wrong on this, my overflow holes are on the top of my sink as shown here:
http://oi63.tinypic.com/11kjul1.jpg
If I pour several cups of water down it or water runs from wet dishes down it I get no leaks (low amount of water waste), but if I put the tap over that waste bit and run it with higher pressure flow from tap it does sadly spring many leaks underneath on the waste overflow part only !
Is this normal ?
If its not normal stay tuned for part II ! again much appreciated for any help.
Is this normal ?
