Dannyparty92
When you are sizing combination boilers obviously for the radiators you calculate how many BTU you need to head all the rads but I'm a little confused about the domestic hot water side of things. Do you get a flow rate reading of the cold main then the boiler you wish to buy must have that particular flow rate reading in its specs or less (as long as it has the correct BTU spec. ?
