View the thread, titled "Slipping on toilet bowl with rubber sleeve" which is posted in Boiler Advice Forum on UK Plumbers Forums.
dubman
I want to insert a new toilet into a pvc pipe by using a rubber sleeve but I think it might be a tight fit. Is there any household type lubricant or cream I could use with the rubber sleeve to make it easier to fit? Thanks
ah sounds good, maybe I will dilute it with a little water - I suppose it won't harm the rubber in any way? Its a soft accordion type sleeve that I think I have to heat a bit to fit it around the toilet outlet. Should I heat it with hot water or a gas lamp?
are you using a pan connector. a pan connector will go directy from toilet into the stack.what type of sleeve are you using ?? is it a black rubber one? for soil
Reply to the thread, titled "Slipping on toilet bowl with rubber sleeve" which is posted in Boiler Advice Forum on Electricians Forums.
