C Cristina Aug 4, 2015 #1 The cistern is filling very slowly, just a trickle. I have looked at various videos and read tips on how to clean the valve from debris but cannot take this one apart!
townfanjon Esteemed Plumber Gas Engineer Subscribed Aug 4, 2015 #2 Hi cristina, imo on a cheap fill valve like that, I personally would just change it . It just ends up being less fuss. Others may disagree
C Cristina Aug 4, 2015 #3 I think you are right. I just found one at Screwfix for a tenner. Thank you!
hammers4spanner Esteemed Plumber Gas Engineer Subscribed Aug 4, 2015 #4 I concur with townfanjon tried to sort one other week would have been less hassle to change it imho.
townfanjon Esteemed Plumber Gas Engineer Subscribed Aug 4, 2015 #5 Screwfix sell fluidmaster valves, look at one of those , excellent valves
C Cristina Aug 4, 2015 #6 Like this one? Would it fit? Fluidmaster Bottom Entry Fill Valve UK ½" | Fill & Flush Valves | NoLinkingToThis
hammers4spanner Esteemed Plumber Gas Engineer Subscribed Aug 4, 2015 #8 Depends if the shanks are same length as well
R REDSAW Aug 4, 2015 #9 disconnect feed pipe from underneath cistern. poke in tube of filler valve and see if there is a plastic mesh basket strainer inside. it may be blocked with debris.. got to take off that to put new on anyway. http://www.boltingdarts.co.uk/Bathroom/ToiletValves/ToiletFillValve3-8/ToiletFillValve3-8-01-33.JPG Last edited by a moderator: Aug 4, 2015
SimonG Esteemed Plumber Subscribed Aug 4, 2015 #10 Blocked filter or split diaphragm, just like the cacky siamp inlet valves.
gassafe Plumbers Arms member Plumber Gas Engineer Aug 4, 2015 #11 hammers4spanner said: Depends if the shanks are same length as well Click to expand... Pretty sure it would be, most modern stuff is I thought
gassafe Plumbers Arms member Plumber Gas Engineer Aug 4, 2015 #12 hammers4spanner said: May fit May not Click to expand... It's not only me who finds the fluidmaster catches the side of the cistern sometimes then lol!! I normally try & secure something at the top of the fluidmaster so it does not catch... A real pain when the siphon is in the way also! The one in the pic does look very close to the cistern wall but a fluidmaster could be made to fit if you chose... Have spent time stripping down those old valves & it doesn't seem to make any difference 🙁
C Cristina Aug 4, 2015 #13 I ll open it and have a look and then get another one exactly the same, probably easier. Thank you all!
