I have a toilet that when flushed is very slow to fill. I've attached images to show what inside cistern is like. Would really appreciate advice. Thanks
I did have valve open before to adjust water flow in cistern after flushing. I thought I had fixed the problem as I was able to flush toilet twice in the space of about 2 minutes. But problem later reoccurred. Any suggestions. Thanks
If it previously filled quicker it could be some debris stuck inside the ball valve. Isolate the water then strip the ball valve to see if its clean inside. Also check the correct cone is in there for your pressure, Red for a low pressure system and White for high pressure.
