Slow leak from pipe in airing cupboard
View the thread, titled "Slow leak from pipe in airing cupboard" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
L
Liz
Hey all,
I have a bit of a leak in a pipe between the pump and thermostat in my airing cupboard. I'm due to ring a plumber I've been given a number for but does anyone know if this is a quick job to fix and how much it might be? I assume it's a straight forward replacement of pipe?
Liz
liz can we have a wider picture showing more of the pipe please. should be fairly straightforward to change just would like to see more.
it might be as said above min of 2h labour plus cost materials , from the photo it does ring the bell that this leak is been going for long time , should have sort it out earlier and would have cost much less .
well its got a drayton 3 port motorized valve above it,soak that pump valve in wd 40 get the footprints drain the system replace one valve ,bit of pipe,cone etc refill jobs a good un,so yes liz its a simple repair £125 is a fair price but ask if some inhibitor could be put back in the system to stop corrosion
I agree about a new pump valve(s) but round my parts this would be nearer £125 for a half day's work.
Or am I missing something?
Sorry, couldn't resist! If I could get £800 for a job like that, I think I would just hand myself over to " Rogue Traders " before they caught up with me! Might be hard to keep up with my Ferrari though!
i have the same job booked in for wednesday + a 22mm gate valve £160/180 depends where you live and a few other factors like rads, accessibility etc.
I can't decide. Maybe it is an illusion! I'm waiting to see another picture.... Shame you scared her off with your £800 quote!! lol
I never knew you could zoom in that far! Now i'm sure it's completely corroded. All my days! I've never seen a pipe corroded that bad!
Reply to the thread, titled "Slow leak from pipe in airing cupboard" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Liz,
jase158,
