Have encountered a small leak below toilet and wanted to see if anyone could advise on how I can try resolve i was going to try tighten but first and if fails check the washer. It is the upper metal nut that is leaking as when I turn the valve the leak stops and it is dry above this point.
Would be grateful on any input to prevent me needing call out . Also if you could advise on tool was going to get an adjustable spanner the area is quite narrow and could not do much with pliers.
photo attached .
photo attached .
