View the thread, titled "Small rental portfolio advice please." which is posted in UKPF Updates and News on UK Plumbers Forums.
With the up and coming Renters Charter, its probably time to start thinking about increasing the efficiency of our small portfolio. 4-small houses.
Two of our four 1990's properties have heat only systems with non-condensing boilers. One on the garage wall and one on the kitchen wall.
The other two properties of a similar age have gas connected, but use E7 electric heaters. Probably ideal candidates for combi boiler systems. Especially as the one bed probably only needs 3 or 4 rads and the two bed needs a maximum of 5 rads. Though the hard water area might make heat only systems a better choice. Both have airing cupboards anyway with water cylinders.
What boilers are other landlords fitting these days? Is there a go to brand/range?
I've always gone for Vaillant boilers in my own homes over the last 40-years, but found them to be on the pricier side. Is it a false economy to buy cheap?
Quite like the idea of stainless steel exchangers as I imagine they will last longer than aluminium, but from a quick look online, am seeing mostly aluminium exchangers. This is a very hard water area and none of the properties are fitted with water softners. I guess if the system water is clean with inhibitor, any limescale will only be deposited in the pipes once!
Is there like a best selling range of boilers that most of the new home developers have been banging in all their properties or do they chop and change?
I have never been a fan of micro bore radiator pipes an prefer the traditional 3/4" pipes myself to carry a better flow of heat. I'm a bit old school like that. Not sure if this would effect boiler choice.
Not looking to have internet connectivity, so if the boilers have that functionality, I'd prefer if it wasn't enabled. Imagine it would be a pain when tenants change the internet routers!
Reliability is always a concern. Don't really need the tenants calling every year with problems.
I did study plumbing and heating at college when I was younger and then worked alongside my father in his plumbing and heating business, so understand some of the difficulties, but obviously things change. Not thinking of attempting this work myself. It will get done by a qualified plumber/engineer.
I know these 'Which boilers to choose' questions come up here often and it can be a pain to respond all the time, which is why I have been reading past threads over this week. Alas, I haven't come across any recent threads about rental properties.
Your thoughts and ideas would be very welcome. Thanks
Chris
Reply to the thread, titled "Small rental portfolio advice please." which is posted in UKPF Updates and News on Electricians Forums.
