I ordered a Glowworm Fexicom 18kw open vented boiler for a customer as it has a rear entry flue.
The reason for this is the cupboard is only 870mm high.
I phoned the merchants and checked clearances before ordering and was told it would fit in the cupboard. They said you need 200mm below for condense plus the height of the boiler.
I have removed the old boiler and didnt think about the pipe work comming out the top! Been looking on the net but does anyone know if there is a smaller boiler available on the market that might fit or if the system version also has flow and return sited at the top of the boiler?
Thanks!
Thanks!
