Bernie2
I wonder how many c/h installers check the quality of the power supply to a wall socket they intend to use, before they link up to it?
Do we know the earth loop is okay? Is the polarity? Des the RCD kick in on time? And so on.
The thing is, its all down to the fitter to check and you would probably soon find that out if there was a fault and somebody lit up when they touched a part of the system.
You might very well wire the system up spot on.
But its the house wiring it draws its juice from, how good is that?
We think its common sense to test the gas pressure and water pressure before we install a boiler.
But do we think the same about the electrical supply?
As you probably know its a bit of mucking about to do a proper wall socket test.
But it is something we should always do or the system may not be deemed safe and its just plain common sense to do it anyway, beside the overriding one of safety.
Incidentally the boiler may not work properly either if the supply is wrong and frying a pcb or two is in prospect as well.
So there are loads of reasons to check the integrity of any electrical supply.
A UK company called Socket and See, make a plug top tester SOK 36. It seems ideal for installers. It does earth loop testing, rcd test and all the other polarity stuff all in the one tester. Its about £40 or so.
The "sparks" earth loop, rcd testers alone cost a small fortune possibly something over £300 each, plus polarity testing gear and the likes as well.
But they are expensive because they can be used all over the place and for many systems and give variable readings to ascertain more information about the system.
The average ch installer is only really interested in a normal domestic wall socket being okay to connect up to.
So outside of fault finding multi meter a plug top tester with its limited dedicated domestic testing facility is really all a ch installer needs.
If a fault shows, before you install, then tell the customer to get it repaired or contact a local "spark" company to do it. You would tell them if it was a water pressure or gas pressure fault, why not electrical power?
The local sparks will kiss you for it and you can pat yourself on the back for bringing to light a potentially dangerous system for the customer.
I think at about £40 the tester is worth a look.
And no I am not on commission off the company, I am just interested in safety.
Incidentally, might be a bit of a market for them. Nice little earner for a ch installer if they can get a sole agency off them.
Sorry meant to add: If doing an earth loop test or any test please read all instructions supplied with the test instrument.
An earth loop test and some other tests, can send a test voltage down the system earth which can damage sensitive equipment such as TV's, video reorders, computers and the like. So don't forget to get the customer to unplug them ans stand clear of any metal objects such as radiators. But you may not need to do any of that if the plug top instructions tell you different.
I must admit I don't know about the SOK36 it seems to test in a different way than the old loop testers. In point looking at the plug top market as a whole, in the last few years new test equipment seems to be coming on to the market that is way cheaper than traditional test equipment. Its not less quality I don't think but more technological advances.
