View the thread, titled "SOG/Fumes at boiler..." which is posted in Boiler Advice Forum on UK Plumbers Forums.
Pssst
Visited this one this week. Punter had had boiler serviced recently by GSR Engineer,had been away for a few weeks but on return and using boiler had noticed a smell of gas/fumes.
No it hasnt. The GSR has just not hooked it over. The inner case was protruding forward enough for the outer case also not to fit properly and i think he had tried to force the front case onto the lugs and that wasnt hooked on properly either on the right hand side !
Scary but easily done, I've not hooked them on a couple of occasions BUT I always run my hands around to feel that it has gone on and remove and refit if not.
Indeed,its something i always do..have a feel around ! Further it was fairly obvious there was a seal issue due to the noise levels when it fired up.Another good sign of something not right. Good thing is was a "modern" combi as could have been worse especially as it was fitted in a bathroom cupboard.
It's a bog standard performa(or similar) for goodness sake.
The easiest cover to replace, but I have nearly done that on other boilers and as Blake, always double check.
Reply to the thread, titled "SOG/Fumes at boiler..." which is posted in Boiler Advice Forum on Plumbers Forums.
