Dannyparty92
Hello all. Why is it that all the soil bosses I fit leak? I cut a 57mm hole in the stack clean the burs off I make sure the four little marks on the inner side of the boss fit in the hole nicely then put plenty of solvent weld about the boss and where it will fit on that stack apply it quickly then tighten up the boss nut? But when I test it after I have left the glue to dry for 24 hours I always see a tiny leak why?
