Soil pipe fittings
View the thread, titled "Soil pipe fittings" which is posted in Boiler Advice Forum on UK Plumbers Forums.
G
gdpamg
I'm looking for some advice on suitable fittings for the setup in this little ensuite.
The current toilet (cistern pictured) will be removed along with the soil pipe up to the point of the t-piece (circled red). The pipe coming through the wall is from the toilet in the main bathroom so will remain.
So question 1: can I just cap off the t-piece or do I need to replace it with a bend?
Secondly, the proposed position for the new toilet is where the sink currently is, so question 2: Would I be able to fit a t-piece on the blue circled section for the new toilet, or is this not suitable?
Hi. Once you remove the wc and soil pipe from branch, fit a access cap 110mm in its place, this will allow roding in the event of a blockage.
A 110mm 92.5 degree branch may fit but looks a bit tight. make sure you Shaffer the pipe ends well and apply silicon grease to both "O" ring in fittings and pipe ends as you will need allow easy movement when fitting in such a confined space. Good Luck
If it was me i'd pull the pipe run apart back to the fitting far left (looks like the stack) and then start again, i think you'll get a branch in ok, problem will be getting a pipe at the right position for the pan spigot. Are those soil pipes at the back there getting boxed in ? are you having a concealed cistern ? If you can create a boxing behind the loo you'll have more space and a better chance of piping up to the pan, maybe with a flexi pan connector ?
wat id do is replace the tee for a bend like you say .. make it look tidier than a tee with a piece and a cap
and for the toilet where the sink is now .. it looks to me like there is an elbow coming out of the wall on the far left ... strip back to that with a new piece in and a bent multi quick
av it!
Thanks for the responses, yes the fitting to the far left is the stack and the pipes will be boxed in, not sure about concealed cistern as its all down to space, its a small akward little space as you can see.
Any advantages/disadvantages of using a multiquick rather than a flexible pan connector?
I tend to view a flexi connector as a last resort if you can't get a multikwik to fit. The problem with flexi pan connectors is that it's all too easy to allow them to sag or contort into awkward shapes restricting the flow and increasing the chance of blockage and making clearance of the pan contents with a single flush less likely.
Mike
Reply to the thread, titled "Soil pipe fittings" which is posted in Boiler Advice Forum on Plumbers Forums.
gdpamg,
Mike Jackson,
