View the thread, titled "Soil Pipe - no cap" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Bird869
Hi all,
I have just noticed that top end of my soil pipe in the loft doesn't have a cap on it. It doesn't smell but seems like it shouldn't be open.
Can someone advise? Should it be capped? Or am I being a worry puss.....
If it is open, then it will need either a air admittance valve to let air in but not out of vent, OR it would need put through the roof & just a cage to prevent birds getting into it.
Capping may result in the toilets, basins etc, drawing the water out of their traps as well as a build up of gas.
It may be the only vent point on your soil pipes & therefore needs vented open to outside or a air admittance valve to inside or outside.
Thanks Best I'll look into that. Looks like someone's done half a job. Just happened to move the loft insulation and there it was, big hole!
I couldn't get my head right above the pipe because of the angle of the roof, I put my fingers down it there was nothing immediately there. I also got the wife to flush the loo and it sounded very open but even with a valve on I suppose it would 🙂
Are you sure you don't have a roof tile vent some times you connect to these with 4 inch flexi pipe
Nothing cut in the roof near it! I was looking to see a roof vent with the bathroom extractor in mind but nothing.
Reply to the thread, titled "Soil Pipe - no cap" which is posted in Boiler Advice Forum on Plumbers Forums.
