V
vdubowner
Hi guys,
1st time poster seeks advice - tried searching the forums for previous threads, but nothing found.
I've just moved into a new build property - 3 storey terrace, with bathroom and ensuite on top floor
after climbing into the loft to install a tv ariel, I've noticed that the soil stack from the ensuite vents through the tiled roof, but the main bathroom pipe stops about 2 feet above the joists/insulation in the loft space, with some sort of polystyrene cap on it ...
so my question is- is this ok, or should it either be connected to the other stack or vented out through the tiles, as well?
thanks for your responses in advance.
cheers.
cheers.
